2x Shock turrets, extreme
2x Front Disclocation Cones
2x +2" front HD Coil Springs
2x Damper front 10"
2x Heavy Duty Front Spring Retention Plate
2x Shock front, bottom “O” rod end mounts
2xExtra clearance rear shock top mount, extreme
2x Rear inclined spring bases + retaining plates
2x Black synthetic slider, extreme kit dislocation
2x Standard Height HD Coil Springs
2x Damper rear 15" Amortizer d.o.o.
2x Heavy Duty Rear Spring Retention Plate
2x Retaining strap
2x Retaining strap quick disconnect
2x Retaining strap, spring clip
2x Shock rear, bottom “O” rod end mounts
2x Polyurethane Extended Bump Stop
3pc +4" Braided Brake Lines
Deflex Polyurethance Bush Kits
Skratka vse kar rabite za preobrazbo z možnostjo montaže
Ve? info na 040 919 777 Peter
Cena: 2250€
P.S. na sliki so zadnje ukrivljene roke, ki jih ni zraven ampak se ukrivijo originalne
[/img]
[/img]
[/img]
